04-24-2024
05:24 PM
09:28 AM
When I print from our laptop I get an error message (little orange triangle lights up) then I push it once and it prints fine. What am I doing wrong?
04-24-2024 05:33 PM
Welcome to the forum!
So that the Community can better help, is the orange error indicator flashing or lit solid? Any other details you'd like to give will only help the Community better understand your issue.
Thank you.
04-24-2024 05:36 PM
it is flashing and says load paper in ltrplain 1 but I open the tray and it is full of paper and not jammed
04-24-2024 05:50 PM
We do not want to use ltr plain 1 we want to use the big tray at the bottom of the printer
04-26-2024 11:36 AM
Following bc I'm having the same issue...
03-26-2025 12:57 PM
Hello,
If you get a message on the printer and you have to confirm the paper size and type to start the printing, it usually means the incorrect printer driver is being used. You can try reinstalling the current version of the Windows driver from our site using the link HERE. It will be at the top of the list and will have Recommended written above it.
If reinstalling the drivers did not resolve the issue, you can also check the paper settings for the tray you have the paper loaded into. Make sure it matches the paper size and type that you are selecting in the print window on the computer.
If you continue to have issues, I suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
