04-25-2024
03:33 PM
03:37 PM
MF656 intermittent comms with MacBook via either ScanUtility or ImageScan; error codes 600104 600007
tried to tackle this with online support last month and it is still a major problem; while using the feeder for successive jobs, error codes pop up at the end of a job and the MF656 scanner is now worthless. Only solution is to remove printer, reboot, re-add printer, reboot...with printer reset....and try to get in another job or two before it happens again. Printer is connected via AirPrint/Bonjour. Have updated the firmware and software update in both of February and April (this month)....hoping that a fix was imminent. OS is the latest Mac. Error codes include 600104 and 600007.
Also the "Associated Products" box in the right margin of the browser screen here is worthless. Might want to fix that. Safari 17.4 if it matters.
Not very interested in being on the phone for another hour or two. JW
03-26-2025 03:21 PM
Hello,
The error would point to a communication issue. If the scan stops after several pages and the code comes up, I suggest power cycling the router that is connecting the devices or improving the signal strength. If possible, you can try changing the connection method by connecting the scanner to your network via ethernet or to your computer via USB.
We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
1. How far is the scanner from the wireless router?
2. Are you able to scan using USB or via Ethernet?
