05-16-2018
01:27 PM
09:34 AM
When I try to use the scanner on the printer, I get this error message:
"Error in scanner.
Follow instructions in the online manual.
Scanner driver will be terminated.
Code: 255,0,0 "
Both scanning and printing were working fine, but I have since moved offices and onto a new network. On the new network, I changed the IP address of the printer settings and printing works. Scanning gives the above error. I uninstalled the MF Scan Utiility, downloaded the latest version of the MF Scan Utility, and tried again, but got the same error.
I'm using Windows 10 Pro.
I haven't reinstalled the printer driver.
What should I do next?
05-20-2018 04:31 PM
05-16-2018 01:36 PM
Hello kQuimbly!
To have a better understanding of your issue, please let everyone know what product you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at usa.canon.com/support or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
05-16-2018 01:48 PM
05-16-2018 07:20 PM
05-20-2018 02:53 AM
There's an existing thread that may help. Check this out:
http://www.community.usa.canon.com/t5/Office-Printers/MF-4890dw-Not-scanning/td-p/53835
05-20-2018 04:31 PM
03-22-2021 06:20 PM
Here's a fix a got from a forum relating to the MF Toolbox. It worked for the MF Scanner as well. Best tip I've ever gotten on a forum. It follows exactly as I received it:
08-19-2015 10:36 PM
This simple fix I found online worked for me:
Start> in the run box type. Services.msc
Scroll down to Windows Image Acquisition (WIA)
Right click, select Properties
Check that Startup type is set to Automatic
Click Log On Tab
Check that Local System account , and Allow service to interact with desktop is checked. Hit apply.
Click Recovery...Click on window next to First Failure, Scroll to Restart the Service. Hit apply.
04-11-2021 07:40 PM
"Click Log On Tab
Click Recovery...Click on window next to First Failure, Scroll to Restart the Service. Hit apply."
What OS are you running? I don't see that option under services.msc for windows 7.
04-11-2021 08:55 PM
I've been using Windows 10 pretty much since Microsoft first rolled it out and I think the Windows 10 installation initially created this problem back in 2015. Everytime I got an update for a long time, the update would reset the Windows Image Acquisition settings. So the specific steps in this solution may be particular to Windows 10 but I think checking and fixing the WIA settings should work in Windows 7. Here is something I found that applies specifically to Windows 7; I don't know if it will work but it seems similar to the one I used for 10:
Follow these steps:
a. Click on Start, in Search box type “services” without quotes.
b. Click on the service which is present at the top of the program list.
c. Scroll down to Windows Image Acquisition (WIA).
d. Double click on it and click the Dependencies tab
e. Make sure, all services Windows Image Acquisition depends on, are running
f. Switch to "Recovery" tab, and change all 3 drop-down boxes to "Restart the Service".
g. Make sure the 2 Reset boxes underneath say "1" in them.
h. Click Ok.
04-11-2021 09:00 PM
Thanks buddy for the response. This is what I was able to find with some digging that worked. Basically, I had to uninstall everything. Run a utility to make sure all registry settings are wiped, and then reinstall the printer driver from c:\. Then reinstall the scan driver.
Hopefully, this will not happen again but I know it will. About half the time I use this MFC I have problems connecting to it. Going to try your solution next time
