imageCLASS MF450 Series - Text is cut off when copying
tmill_2242
text is cut off when copying. I tried changing sheets and customize. nothing works. It did work at one time.
3 REPLIES 3
Kristoff
Rising Star
Thanks for joining the conversation, tmill_2242!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. Also the operating system you are using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
tmill_2242
MF450
So the MF450 series has a number of printers in its product line, with its own slight changes and features (example: MF451dw, MF453dw, MF455dw, etc). Normally the model number would be located on the front-facing panel of the printer, on the bottom right corner. Please indicate which exact model number your printer is.
