04-15-2019
05:32 PM
08:48 AM
James_C
I just bought a new computer running windows 10 home and cannot get the computer to recognize the MF3240 as anything other than a scanner. I've reinstalled the drivers from the Canon site and no luck. It only comes up as a scanner. My previous computer was also running windows 10 home and worked without issue. Any help is appreciated.
Thank you.
04-22-2019 10:51 AM
Hi yrabins.
The printer driver must be installed manually on the Windows 10 operating system. Please follow the instructions below to install the driver:
1. In 'Downloads', you will see two listings (one will look like a clamp icon, the other will be a yellow file folder icon) with the name MF3240_MFDrivers_W64_us_EN.exe. Drag the yellow file folder icon to your desktop.
2. Connect your printer to the computer.
3. Close the 'Downloads' folder.
4. Right-click the 'Windows Start Button' and then click 'Device Manager'.
5. In the middle section of the window, you should see a listing that says 'Other Devices'.
6. Click the drop-down arrow beside other devices and you should see the Canon listings there.
7. Right-click on the first listing and select 'Update Driver Software'.
8. Next click on the 'Browse My Computer' option.
9. Click 'Browse' again and then scroll down in the window that pops up and select the folder you dragged to your desktop.
10. Click 'OK' and then click 'Next'.
After it updates successfully, close the window and repeat the steps for any remaining Canon listings.
04-22-2019 12:57 PM
Thank you. I tried that and it still only recognized the device as a scanner. I finally right clicked directly on the .inf file for the printer and had it install from there and it worked. Still having issues with the scanner, but being able to print was the priority.
07-21-2019 11:22 AM
How do you install from the .INI file?
07-21-2019 11:22 AM
I mean .INF file
07-21-2019 11:27 AM
Does not work. It shows in the Devices and I can work it as a scanner, but not a printer. Had no problems in the othe Windows 10 machine, but have a new Dell laptop and will not work. I also installed the patch MF3200USBScanPatchW64EN. Does that create the problem?
08-30-2019 06:43 PM
This is what worked for me:
Find the installer folder that was created when you did the driver install. Mine was in C:\Users\myusername\Downloads\MF3240_MFDrivers_W64_us_EN
Right Click on each INF file, then choose install.
There were 3 INF files in the 64-bit installer folder:
MF3200AU.INF
MF21SCN.INF
CNXRPUA6.INF
I assume that there is one each for the printer, scanner and fax. I just did all three and the printer comes up just fine afterwards.
I am assuming that the reason this happened to me is that I use a regular user account (non-admin) and then put in my user credentials (different account) when I do software installs. I'm guessing this confused the driver install process.
03-22-2020 04:23 PM
04-13-2020 04:33 PM - edited 04-13-2020 04:39 PM
I can't thank you guys enough for this support. I have a Canon printer/scanner/copier that I really like that I haven't been able to use in about 4 years because the computer that it was connected to crapped out and - UNTIL NOW - I haven't found any suggestions that worked.
I am now connected to my 1 year old Samsung laptop and my printer is now working again. YAY!!!
04-13-2020 04:38 PM
Hi yrabins,
Try the suggestions of giacobe in this thread. Installing the 3 individual *.INF files from the Canon MF3240_MFDrivers_W64_us_EN download worked for me, and I've been trying to find a driver (or driver installation method) that would work for probably 4 years.
