01-13-2024 01:43 AM - last edited on 02-28-2024 01:40 PM by Kristoff
One day I tried turning on my printer and it just looked like this. I tried turning it off and on, same thing. Has anyone else run into this issue before? How did you fix it? Thanks in advance!
01-13-2024 08:30 AM
This is a progress indicator that displays during the printer's power on self test.
Try unplugging the printer. Press and hold the power button for 30 sec., then release.
Now reconnect to power and retest.
Typical causes for this behavior:
Unexpected loss of power
Power supply failure
Power surge or dip
Also check all doors and access panels. Remove and reseat your paper tray.
If it doesn't correct itself, your printer will require inspection and service.
01-21-2024 08:15 PM
Hi Rick,
Thanks for the help! Unfortunately, it didn't solve the problem.
02-28-2024 10:47 AM
Hi Sunny I am experiencing the same issue right now, my screen is stuck as well. Were you able to resolve this issue? and if so, what did you do?
02-28-2024 01:38 PM
Still no luck
