canon scanner DR-G1130 not up to speed in scanning
dseiffert
I have recently purchased a Canon DR-G1130 ImageFormula high speed scanner.  Installed the driver and other software onto a Windows 7 system with 2 gb ram.  When I went to scan a large document it only scanned at 30 ppm. I checked the settings of the software and the scanner settings (set a high speed).  How do I get it to scan at its advertised speed of 130 PPM!?!?!
1 REPLY 1
wpth1234
Not sure if this is the answer, but if you scanned using OCR, or optimized on your initial scan  it scans slow. I always find it best to scan, then OCR alot faster
