04-11-2022 03:13 PM
I have an ImageClass Color MF743CDW which is connected wirelessly to the network. I am able to print to it via my phone and computer when connected via wifi. When my computer is hard wired to the network it error out though. My assumption is that it cannot find the printer on the wired network. How can I fix this?
04-11-2022 09:01 PM
You only have ONE network. A device CONNECTS to it by wire or by wi-fi. A connection is a connection. They are BOTH Ethernet connections.
If the computer connects by an Ethernet cable, and you've verified that (doing any online activity, like email or surfing the Web), cable is more reliable than a wi-fi connection.
Does your printer's setup require choosing between wi-fi and cable connection?
04-11-2022 09:13 PM
Thanks for your reply. I am aware that it is one network, which is why I find it strange. The printer has both wired and wireless option but I want to use wireless.
04-12-2022 01:24 AM
You say it works wireless, so what's the problem?
Did you look at printer settings?
04-12-2022 10:10 AM - edited 04-12-2022 10:12 AM
He said he could print if the device he is printing from are connected to the network wirelessly.
What is the IP address of the printer?
What is the IP address of the computer when its connected via ethernet?
No sure? Check you router. Admin portal, connected devices.
Once you have this information, try...
pinging the printer from a command prompt
and/or
opening the devices print server in a browser. Open a browser and enter the IP of the device.
04-18-2022 04:32 PM
Hello Bkuhlmann,
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
04-20-2022 08:14 PM
Hi Hector,
Thanks for your help. I am running Windows 10 Enterprise edition. My computer is wired directly to the switch, as is the router (from a different wire). The error just says "Error printing from MF743cdw". But if I remove the ethernet from my laptop and connect to the WIFI it prints with no issues.
Thanks,
Ben
04-25-2022 03:35 PM
If you connect via wifi, the computer would talk directly to your router without the switch. If you connect to a switch that is connected to the router and you lose connection to the printer, it will usually point to a configuration issue with the router and switch. In this situation, I would suggest checking the switches settings to make sure everything is configured properly with the switch's manufacturer. You can also try contacting our support team at 1-800-652-2666. Our agents would be happy to assist with checking the connection to see what is going on.
