08-22-2021 03:15 PM - last edited on 01-22-2024 11:57 AM by Kristoff
The printer is unusable on macOS - I am currently on macOS Big Sur V11.5.2 and:
Canon please fix your drivers with each macOS release in a timely manner, my device is a home/office printer turned paperweight for several weeks now - otherwise please provide a means for customers to return faulty printers.
As of this thread, I have tried
Nothing works - I'm extremely frustrated.
08-24-2021 10:55 AM - edited 10-03-2021 11:32 PM
It sounds like you are having an issue with basic connectivity. How is the printer connected and to what?
Wired LAN - Verify the connection on your router.
Wireless LAN - Perform manual set up:
Verify the connection to your router. If connected, it will be listed under attached devices and display with its assigned IP address.
Software needed for install:
Downloads for your product are here:
Support | Color Laser | Color imageCLASS MF743Cdw | Canon USA
Note, I didn't see any files called MF741/743C or Canon MF741/743C CARPS2 under the drivers or software tab for Mac OS 11.x Big Sur. If you are not using drivers downloaded directly from Canon, unexpected results might occur.
It might be best for you to start over. Remove the printer from Apple menu > System menu > Printers and Scanners (using the (-) minus key.
Drag any Canon or non canon software / utilities using finder to the trash, then restart your system. Now start over, confirming that the printer (regardless of how its connected) is on the same network as your MAC.
All Canon drivers currently list support through Mac OS 11.4, but its likely 11.5.x will also be supported.
09-29-2021 04:50 PM
No it isn't basic connectivity, its an outdated driver issue on Cannon's side for macOS.
The drivers I mentioned are from the official packages from Cannon, you are able to select them when you have installed their packages.
09-29-2021 10:16 PM - edited 09-29-2021 10:23 PM
Dear Canon-
As a long time user of the MF series, this user's issue is 100% valid. There is something majorly wrong with your drivers.
In the past, I could use my apple airprint to select DPI on Apple Preview for scanning. For some reason, whether new Mac OS, or some other issue, it is stuck at 300 DPI with no way to change it.
I need to scan a document at 200DPI to save on file size. SO... I read I needed to install your drivers...
Queue 2 hours of frustration and headache. Not only did your drivers not work, it gave the dreaded message that I needed administrator access to use my scanner, which is complete BS from top to bottom.
This also caused major issues with the original Apple Secure Airprint which allowed me to use both the printer and scanner. For several restarts I could not install the scanner function anymore even with Airprint.
I had to completely remove Canon's drivers out of the library files and everything, restart machine multiple times, and finally was able to get the scan function back through Secure Airprint.
I generally think these Canon printers work great, but you definitely need to review issues with the drivers. As is, they do not work smoothly. I will be calling support tomorrow to report the issues.
Thank you.
09-29-2021 10:19 PM - edited 09-29-2021 10:24 PM
By the way, I am running OS 11.5.2 BIG SUR.
TMANZ, I would suggest deleting all the Canon drivers and using the native Secure Airprint. It works just fine wirelessly.
09-30-2021 01:32 PM - edited 09-30-2021 01:50 PM
One way to avoid these types of issues is to confirm drivers support BEFORE upgrading your OS to a version that might not be supported by the drivers you currently have installed. Its a users responsibility to verify support before upgrade.
This may be unpopular, but no one is forcing operating system upgrades. If you uncheck the box "Keep my system up to date" you are able to control when updates occur. Upgrades should be planned and on your terms. Otherwise surprises and unexpected results can occur.
No one wants to hear this, but its true none the less.
09-30-2021 01:45 PM
@shadowsports You are making the false assumption that either of us did an OS upgrade without reviewing the drivers. The drivers in my case are supposedly updated for my current OS and THEY DO NOT WORK PROPERLY.
10-03-2021 11:58 PM - edited 10-03-2021 11:59 PM
@tmanz wrote:No it isn't basic connectivity, its an outdated driver issue on Cannon's side for macOS.
This is what I got when I searched Google for MF741/743C or Canon MF741/743C CARPS2 drivers
Please download your drivers directly from Canon's website:
Support | Color Laser | Color imageCLASS MF741Cdw | Canon USA
As you can see, none of the drivers available for Big Sur 11.5.2 have the words CARPS2
If there are other drivers you are aware of I'd be grateful if you could point me to them. If not, I suggest you stick with my original suggestion and use drivers from Canon's support page.
10-04-2021 12:11 AM - edited 10-04-2021 12:13 AM
@lunchboxaudio wrote:Dear Canon-
Thank you.
Ready to pick this back up with you lunchboxaudio.
We know you are running BigSur 11.5.2
How is your printer connected USB, Wireless or Ethernet?
Permissions issues are likely related to the OS, not the driver.
If you have contacted support and your issue is resolved, you can disregard.
10-04-2021 12:41 AM
