03-29-2021 03:40 PM
After the last Windows 10 update I have been unable to scan. Followed directions on support page, uninstalling and reinstalling drivers, while pausing firewall and restarting computer in between. Done same sequence 4 times with no success. Still cannot scan. Please help!
03-30-2021 11:12 AM
Do you receive any error messages?
To verify what you believe is the issue, you can:
-Uninstall the latest applied updates
-Use system restore to roll back to a point in time when scanning "worked"
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
03-31-2021 03:21 PM
I have uninstalled the Windows to the point when the scanner was working. Uninstalled and reinstalled drivers while in safe mode and still not working. Same thing is occurring with a different Canon printer. I can print to both of them but am unable to scan. Get error message that driver is not installed.
Please help!!! I need this for my job.
05-20-2021 04:14 PM
Hello Drtonyamiles,
If you are getting a driver error when you attempt to scan and you have already tried reinstalling the drivers, It will usually mean something is blocking the scanner driver install or the wrong drivers are being installed. In this situation, I would suggest disabling any security software that you are using on your computer and then trying to install the [Windows 64bit] imageCLASS MF8280Cw MFDrivers (UFR II / FAX / ScanGear) and the [Windows 32-bit & 64-bit] Patch for Network Scan, USB Scan found at the link below.
Once you have installed both, you can try scanning again while the security is turned off. If you still have a problem with scanning, I would suggest contacting support at 1-800-652-2666 to see what might be preventing the driver from intalling.
