08-02-2022 02:57 PM
I was dusting this off after some construction in the office and it is now stuck open. I don't want to force it shut and break it! See attached photo for current state!
08-02-2022 04:23 PM
Hi, knwatts!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
08-25-2022 05:47 PM
Hello Knwatts,
If the lid will not close on the MF8080Cw, you can try removing the toner and while the lid is all the way up, you can check the hinge for any debris or obstructions. If the lid will not close while the toner is out, it looks like the printer needs service. You can check your support options by calling support at 1-800-652-2666 or logging into your MyCanon account.
