01-25-2022 03:20 PM
I have a problem with a Canon Imageclass mf743cdw that when i send a print job, the printed sheet comes out then re-feeds its self back into the machine and then spits it out but i have 2-Sided Print Off on the print Driver. Same thing happens when i make a copy from the glass.
01-27-2022 01:50 PM
Hello Rotsen,
To keep the paper from pulling the paper back in and turning the paper over, you can go into the menu using the steps in the link found HERE and change the feed method from print side priority to speed priority.
01-27-2022 01:50 PM
Hello Rotsen,
02-08-2022 12:02 PM
Thank you Hector and my apologies for the late reply. Did make the adjustment as you indicated and all okay. Now the re-feed is deactivated when printing.
01-06-2025 04:21 PM
I have the same issue. I tried the above and made sure double sided preferences are set to one sided.
