12-29-2024 12:51 PM
The Canon MF656cdw printer behaves unusually: each page is printed, comes out of the machine, gets pulled back in, and then comes out again. The print quality remains perfect throughout. It almost seems like the printer is preparing to print on the other side, but that’s not the case. I recorded a video to demonstrate the issue. - Brand new Machine.
12-30-2024 08:30 PM
If it is set for 2-sided printing, that's what it will do, even if there is nothing to print on page 2.
12-30-2024 09:31 PM
Sorry I didn't reply to this earlier. I started penning a reply, then stopped.
The behavior you describe is exactly what you think it is. The printer can print duplex (both sides of a sheet). It does this by printing one side, pulling it back in and printing on the other side.
There can be a few reasons.
One occurs If you have a extra blank page saved with your document or like @MREG stated, having 2 sided printing selected in the printer driver.
01-06-2025 04:20 PM
I have tried changing all the settings to one-sided printing and its still re-feeding. I have also found another post recommending this follwoing which also didnt correct the issue: To keep the paper from pulling the paper back in and turning the paper over, you can go into the menu using the steps in the link found HERE and change the feed method from print side priority to speed priority. Any suggestions. its so frustrating.
