My MX922 will not do ANYTHING
busynest
My MX922 will not do ANYTHING. The lights are on, but nothing happens. It will not copy, print or fax. It will not move from one feature to another. I have shut it down a number of times, unplugged it even more often. It always comes back on, makes a few noises but then nothing. It will not respond to pushing any buttons. Can someone help me???
7 REPLIES 7
Jenine
Rising Star
Hi busynest!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/Canon-Support or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
I'm using Mac El Capitan. But I don't think that's the issue at all. Because I can't even make a copy. The machine is completely non-responsive even tho it makes normal sounds when i turn it on. I had been able to print wirelessly, but now it will not respond even connected to USB.
jrhoffman75
Is it brand new, or was it working at one time and now it has stopped working?
I've had it about 2 months. It worked initially. I could copy, print wirelessly and fax. Now nothing moves when I hit any of the buttons, even tho the lights are on.
I recall seeing a post a while ago for a similar problem. If I recall correctly the instructions were to unplug, press the power button (to drain any stored energy) and then let it sit unpowered overnight.
If that doesn't work you could call 1-800-OKCANON
busynest
Thank you. I'll give that a try!!!
I tried that and it does work...for a day or two and then freezes up again. So unacceptable. I will call Canon next week. Thank you for your help and suggestions.
