11-16-2020 09:39 AM
I have upgraded to OS Big Sur and successfully downloaded the driver from usa.canon.com for my ImageClass 227 dw printer. When I try to print something I get a "error in printing message." Help. Thanks. paul
03-14-2021 03:19 PM
Hello,
I have been looking all over online for a solution to this same problem!
As I was about to give in a probably buy a whole new printer, I started looking up printers compaptible with Mac Os Big Sur and came upon a site that listed a bunch of different printers. When I clicked Canon printers it was actually the EUROPEAN version of the ImageClass series called iSensys. Same printer just a different So I googled the ISensys Canon site and found the driver here. Same picture as the Canon ImageClass Mf229dw series just different model name. It worked for me!
Please try this or a similar European version of your printer driver.
Good luck!
03-31-2021 06:57 AM - edited 03-31-2021 07:37 AM
I'm having same issue trying to print wirelessly.
Was work fine on Big Sur 11.2 until recent update then I wasnt able to print and after removing the printer and resetting the print system I was not able to see the device anymore. All I saw was Virtual Scanner II. I tried new downloads of latest drivers - no luck.
So I decided I'd try 11.3 Beta 5 to see if that helped - no luck. Updated firmware directly from the printer via internet - no luck and now I cannot print from iPAD and iOS which was working previously
I've tried European drivers no luck.
Canon what's the remedy before I throw this thing in the trash.......
Twister
03-31-2021 12:32 PM
03-31-2021 01:06 PM
Hi ehsanesf - my model is MF624CW which I tried a version of but no joy.
I can print via LPD to IP address but now nobody else can print from iPAD or iPHONE which did work perviously and I have no scanning capability at all.
04-22-2021 11:55 PM - edited 04-22-2021 11:56 PM
Has anything been resolved here? I'm so confused. I got my new imac in February. I set it up. I added the MX882 thinking it would be difficult, and it was a breeze. The Canon website said that the MX882 wouldn't need drivers, so I didn't download any. The imac found it easily with bonjour I added it and it worked. So easy. And I could print from anywhere in the house on any device. I was pumped. It worked up until about 5 days ago. My son says the printer isn't working.
So I come in and try to reinstall it, and first it couldn't find it. So I had to reconnect the printer to the wifi (didn't have to do that the first time. When I finally did that, ios says it can see it. I go to add it as a printer, and it's asking for drivers. And won't let me add it without a driver. Canon says I shouldn't need drivers. What gives here?
HELP
04-23-2021 06:29 AM
hi JoWall, no response from Canon or anyone with solution so I bought another printer from Brother, works fine. Will sell the Canon and not get one again.
04-24-2021 09:06 AM
OK, like other here, Have MacBook Pro M1 2020, Big Sur11.2.1, using canon mx922 the printer prints, but when I try to use the scanner SAYS " The application “Canon IJScanner5” can’t be opened." I have down loaded drivers to no avail. It is frustrating.
1. Is there solution ?
2. Does Canon not support Big Sur11.2.1, ?
3. I don't believe I am the only person in this situation.
4. Help?
04-24-2021 09:13 AM
05-03-2021 06:57 PM
Canon won't take my call. They tell me that they don't support my printer so won't even pick up the phone for a conversation. Might possibly be the worst customer service I've ever encountered.
05-11-2021 05:09 PM
Thank you,
This worked for me! Canon mf269dw connected to imac Big Sur with USB cord.
