12-30-2015 06:14 AM
I have upgraded my computer from Win7 to Win10 with a clean install with only one small problem, my printer.
The printer works OK except for the scanning function will not scan a document, so I called the Canon tech support and he walked me through installing the new drivers up until the last step of the installation when a notice popped-up saying "Canon Driver Installation has stopped" at this point the tech guy suggested we temporarily turn off the Windows Defender software and the Malware I have installed, I did that but it had no effect, I still got the same pop-up warning so he didn't know what else to do and suggested I call Microsoft.
So, I called MS and explained the situation to them and they quickly told me it was not their problem because it was a driver issue and that is Canon's problem, so I am in a catch-22 situation and I really need the scanner.
Any help would be appreciated.
12-30-2015 02:40 PM
You might try turning off the Windows 10 auto-printer management before installing?
Click on the Windows icon in the lower left, select Settings. Click Devices, then Printers & Scanners. Scroll to the bottom and toggle "Let Windows manage my default printer" OFF.
Try to install again (preferably from the web instead of the disc). Best of luck!
12-30-2015 02:40 PM
01-01-2016 09:23 AM
Thanks Merrymary that solved the installation problem, however, it has brought up another situation.
Now that the scanner works I am trying to scan some printed text in to a word document. I have followed the instructions in the scan utility but all I get is garbage. Before I went to Win10 I could do this without any problem, any other suggestions?
01-04-2016 09:27 AM
Hello jkraut.
The OCR capabilities with the included software are very basic. The software is only able to detect simple text-only documents. If special fonts or formats are used, the text may not be detected properly. You may have to purchase dedicated OCR software separately in order to proecss your documents.
If additional assistance is needed, find more help at Contact Us.
