11-04-2015 06:49 AM
I could really use the ability to print a pattern for color adjustment.
According to the manual, it's supposed to be at the bottom of the dialog that appears when you selection Printer properties> Main> Color/Intensity > manual > set.
The dialog I get has no options at the bottom.
Since I was using 4 x 6 in. paper, I thought it might be because of the paper size. However, the "print a pattern for color adjustment" fails to appear even with US Letter size photo paper selected.
How do I access this feature?
Thanks,
Dave
11-04-2015 09:14 AM
11-06-2015 11:41 AM
Hello.
The print dialog menus of your programs are unique to the software. You would have to access the Preferences or Properties of the printer through the Print dialog menu in your program in order to access the printer settings.
Check the documenation for your software to see if these adjustments are possible in the program.
11-06-2015 01:51 PM
