09-27-2014 09:25 PM
Hello, everything was working just fine until a couple of days ago. I usually scan from the MF8580CDW by: select scan type > computer > select destination > custom 1 > confirm destination. Today I receive the following error on my computer: "MF Toolbow that is supported by the scanner you are using may not be installed on your computer. Install the appropriate MF Toolbox, and then perform the operation again."
However, when I scan FROM MF Toolbox 4.9 > custom 1 > Start > it scans.
I much prefer to scan from the scanner because I don't want to keep walking back and forth. I have a PC with Windows 7.
Thank you for your help.
09-30-2014 03:07 AM
Hi rba.
I recommend uninstalling and reinstalling the MF Toolbox software. Please follow the instructions below:
1. Open [Programs and Features].
2. Select [Canon MF Toolbox 4.9], and then click [Uninstall].
3. Click [Remove].
4. Click [Exit].
Next, reinstall the MF Toolbox:
1. Insert the User Software CD-ROM into the slot on your computer.
2. Click [Custom Installation].
3. Check only the MF Toolbox checkbox, and then select install.
4. Restart the computer.
Next, verify that the Toolbox software is closed on the computer and scan a document. Please ensure that you are logged into an administrator account.
I hope this information is helpful to you. If the error persists, please contact us at 1-800-OK-CANON (1-800-652-2666).
10-05-2014 04:13 PM
Hello, thanks for your reply. However, I am still getting the same error message. I had to download MF Toolbox from Canon support and it is ".mf17". Thank you for taking the time to answer. I wish it had worked.
04-23-2015 06:49 PM
04-27-2015 03:58 PM
Yes that problem is solved. I might have ended up calling Canon support. They are very helpful. I've called them a few times for another issue, which I have now written down how to solve. I suggest calling them. Good luck!
04-27-2015 04:38 PM
What did you do to solve that problem?
04-28-2015 12:12 PM
I don't remember exactly what I did. As I said earlier, I may have called for help. However, I do know that I deleted the existing MF Toolbox that was on my computer and downloaded a new one from the Canon website. It's also possible that I deleted and reinstalled the printer (which only takes a minute). To do that go to your control panel > Hardware & Sound > Devices & Printers > select your printer and delete it. Then add printer. Hope this helps.
