MF8350Cdn color prining problem
crowleyd102
All color prints had pink tinge, replaced magenta & cyan toner, now blue horozontal bars
Thanks
Hi crowleyd102!
I know this issue is frustrating.  I recommend performing a fixing unit cleaning and image transfer belt cleaning.  Please follow the instructions below:
Fixing Unit Cleaning
1. Press (Menu).
2. Scroll to select <Adjustment/Cleaning>, and then press [OK].
3. Scroll to select <Clean Fixing Unit>, and then press [OK].
4. Confirm that paper is loaded, and then press [OK].
Load paper of the type displayed on the screen.
Cleaning starts. It takes approx. 68 seconds for MF8350Cdn.
* We recommend that you should use plain paper to clean the fixing unit.
NOTE:
If cleaning does not start, check if any jobs are stored in the memory.
When some jobs are stored in the memory, this function is not available.
5. Press [  ] (Menu), then close the menu screen.
Clean ITB
1. Press (Menu).
3.  Scroll to select <Clean ITB>, and then press [OK].
4. Press [OK].
Cleaning starts. It takes approx. 51 seconds for MF8350Cdn.
5. Press (Menu), and then close the menu screen.
If the error persists, after performing these cleanings, I recommend using genuine Canon cartridges.  We are unable to provide support for third-party cartridges.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
10 REPLIES 10
Stephen
Moderator
Moderator
Hi crowleyd102!
Welcome to the Canon Forums and thanks for posting!
So that the Community can help you better, we will need to know if you see any error messages either on the computer or on your printer, we'll also need to know the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your printer (USB or networked via WiFi or Ethernet).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
1) No error messages
2) Windows Vista
3) Ethernet connection
4) Toner (not Canon) from InkPlusToner.com - NTCH53 series
5) Scanned image -
Hi crowleyd102!
1. Press (Menu).
NOTE:
Clean ITB
1. Press (Menu).
4. Press [OK].
When the Clean ITB does not resolve the misadjustement problem of the color you can clean the image transfer belt.
What must be cleaned is the right INNER side of the belt.
To do so you can use a bended cotton stem , place it under the upper right side of the belt and slowly move toward you the belt with a clothed protected hand (avoid greasy stains)
you will be surprised of the dust and toner powder recovered by the cotton .
Change the cotton stem until no more dust with the move of the belt.
After that, blow with a dust remover (gaz under pressure) along the inner right side of the ITB.
All this has finaly fixed my recurent trouble of color misalignment.
Problems have begun with the use of leaking OEM cartridges.
Hey gpajot,
Can you tell me how to get physical access to the belt?
I guess you have to remove the toner cartridge tray, but I have no idea to do that.
Hope you can help.
Slide toward you the cartridge tray until it stops.
It is blocked by a little wire at the end of the LEFT rail, you must insert a narrow knife  or little screwdriver to slide it up in order to unlock your cartridge tray from the rails.
BEWARE with the belt !
It is sensible to water on your skin!
Use gloves, second effect: you will be able to hand run the belt in order to clean it external and inside the first rigtht centimeters.
You can also use compressed-gas dusters to remove ink powder, (not for your lungs !!) plus vaccum cleaner.
The trouble seems to be the use of poor YELLOW ink ?
To be confirmed
Hey gpajot,
Thanks for your reply.
I'll give it a try when I have enough time.
We only use good Canon toners so the cause is kind of unknown.
The trouble only started when we were printing out photos and changed one of the advanced settings from 'Standard' to 'Photo'.
From what I can see, the belt looks kind of wavy. It's hard to see with the toner tray in the way.
First color photos were coming out black and white.  Now everything comes out blank, even black and white stuff.
If the ITB is ruined, we might just go back to an inkjet printer.
I'll let you know how it goes.
Cheers.
This did the trick.
I managed to pull out the tray, pull the belt towards me, and give it a good wiping over.
It seems like the belt might have actually been stuck too, or the rollers might have frozen for some reason.
Thanks so much!
joudy
I have a problem with my printer , i try to print with color from PC but it doesn't work but when i print from USB or memory card it's works . Canon MP640
