MF753cdw printer won't go into sleep mode
mnsandler
my mf753 suddenly won't put the Printer device into sleep mode. Nothing has changed since putting this unit into operation 2 months ago.
I did notice this was happening when the fax device was trying to answer the phone call. I have since disabled auto answer on the fax service. no change
I have the auto sleep timer set @ 3 min
any suggestions for other things to look at?
mnsandler
OK. so disabling the auto answer caused the problem. As soon as I reenabled the Use Incoming Ring setting the fan stopped running continuously. I set the number of rings higher than my answering machine since the answering machine isn't plugged into the canon directly.
I hope this helps others.
1 REPLY 1
mnsandler
