08-15-2023 06:49 PM
I'm setting up this printer for the first time and running through the various settings. I was able to scan documents fine and customize the settings using the Canon MF Scan Utility.
However, I'd like to rename Custom 1 and Custom 2 to something more intuitive based on my custom settings (ex. Color Scan 2-sided). Is this possible?
Thanks!
10-24-2023 03:37 PM
Hello Palacekeeper,
Unfortunately, we do not have any settings in the MF scan utility that will let you change the name for custom 1 and 2 .
10-24-2023 03:47 PM
Thanks for confirming. I would suggest adding this as a feature request. The very idea of a custom selection implies that it should be able to have an intuitive name. Thanks!
11-06-2023 11:20 AM
What about adding buttons to the printers screen for the functions you created and renaming them.
