07-01-2023 10:34 PM
On this printer, is there a way to turn on Remote ui after the setup process is complete. I went through all of the menus but couldn't find a place to turn it on. Is it only available during setup? TIA
07-02-2023 11:01 AM
Rick. Sorry, I finally got to log in. The Menu button was not showing up, so I did a full reset and more menus appeared including "Menu. Thank you!!!!
07-01-2023 11:20 PM
You can access the remote UI using a web browser.
See this for assistance:
Starting Remote UI - Canon - imageCLASS MF753Cdw / MF751Cdw - User's Guide (Product Manual)
Note you will need to create a PIN during set up. Keep this in a safe place.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
07-02-2023 08:06 AM
On my printers control panel when turn on there is a general tab listing ways to print. There is no Menu button. I've gone through the six Custom tabs. None of which have a " Management Settings License/Other1 Remote UI Settings" anywhere to be found.
07-02-2023 09:23 AM
Did you see the reference from the user guide I posted? Enter the machine's IP address in a browser. This opens the remote UI on the printer's webserver.
07-02-2023 09:38 AM
Yes I did that only to receive the message:
At the printer there is no management setting menu as described in the link you have abouve. The only thing I could find on the menus for remote ui was under application library guide that show a nice little photo of a address bar.
07-02-2023 11:01 AM
07-02-2023 11:20 AM
All I did was point you in the right direction 😃. You figured it out. Good work.
