07-31-2021 09:01 AM
Having an issue with my MF743. When I place paper in the Automatic Document Feeder (ADF) and try to either copy or scan, nothing happens. There is no audible sound made to indicate that the printer senses paper is in the ADF.
More than likely, I think it would be a faulty sensor more than a firmware/software issue.
Any ideas on how to resolve this issue?
07-31-2021 06:13 PM
Finally figured it out after taking apart the ADF to look at the internals. A cable was unplugged. Read below for further information:
The following parts below are what sense the paper and are what were unplugged.
FLAG,SENSOR - Part # FE8-3448-000
PHOTO INTERRUPTER - Part # WG8-5935-000 IC
The cable connecting these sensors to the main board was unplugged because there is literally zero slack in the cable. The ADF literally lifts off the flat bed scanner glass, if you lift up on it because it is not secured to the top of the printer.
In my opinion, this cannoin printer's issue simply boils down to poor product design because it's very easy to accidently lift the ADF off the printer if your moving the printer from one area to another.
Hope this helps someone in the future.
07-31-2021 06:13 PM
