MF743Cdw - Why are there two "Clean Fixing Assembly" options?
david07666
Enthusiast
On my MF743Cdw, when I go to to Adjustment/Maintenance -> Maintenance there are two different options to clean the fixing assembly.  What's the difference?  When I select the second option it does some processing and then prints a sheet with a large, completely black chevron.  When I select the first option, it does some processing and emits a blank sheet.
Here is the difference:
<Maintenance> - Canon - imageCLASS MF746Cdw / MF745Cdw / MF743Cdw / MF741Cdw / MF644Cdw / MF642Cdw /...
3 REPLIES 3
david07666
Enthusiast
Right you are, Rick, how did I miss that?  I don't know!  Thanks
Happy holidays to you.
