06-25-2019 09:29 PM
06-28-2019 01:07 PM
Hello I found the Issue, I was using the Windows "scan" app and that must be the problem because I switched to the "MF scan utility" and it works fine now. Thanks.
06-28-2019 01:02 PM
Hi Nwsw.
Please lift the platen cover and verify if you see anything on the rectangular portion of glass that may be causing the issue:
If cleaning the glass does not resolve the issue, or you are unable to locate an obstruction, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays). A representative will be able to further assist you.
06-28-2019 01:07 PM
