02-18-2024 12:40 PM
I have a document with large color swaths that are supposed to print in a teal color, but are being printed in a blue.
It prints in blue from either Acrobat or Word. The HP Officeject prints the color more faithfully, pointing to an issue with the printer and not necessarily an issue with the printing app.
For about 300 copies it printed more faithfully. And I restarted the printer and laptop and it is back to printing blue.
It SHOULD be printing the following colors:
However, it is printing closer to an RGB: 0 121 195 or even darker blue.
I've tried a TON of different things that I'll detail below, to no avail. I'd LOVE some pointers on what to try next.
This has been true on both MacOS 12 & 14.
Here's what I have done so far:
I can't find any on-printer settings that might impact the color reproduction. Of course, I can manually change the color deposition for all prints by manually increasing magenta and experimenting until color reproduction increases.
Suggestions on how to adjust the printer?
02-26-2025 10:12 AM
Hello,
From what you are describing, it looks like the colors might need to be manually adjusted or the shade of teal is outside of the color gamut for the printer/paper. To see what might be going on or to see what color settings need to be adjusted, I would suggest contacting support over the phone at 1-800-652-2666. They would be able to review the settings, check sample prints and see what might be going on with the hardware.
