12-07-2019 11:48 AM
I just got this printer. Installed software. Scan Utility loads fine. Got the latest driver from Canon. Printer prints great.
BUT... the Toner Status app will not load. It shows it is installed. But click on it and nothing loads. Ideas?
12-09-2019 03:22 PM
Hi, Sven62.
If the MF644Cdw's toner status isn't getting to the computer, but everything else is working over the network or USB connection, try disabling your firewall or antivirus. If that corrects the problem, then you'll need to refer to security software's documentation and support for directions on creating exceptions.
If you need immediate assistance with this issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
08-15-2023 09:35 PM
I'm having the exact same problem. Disabling my Avast Anti-Virus software including the firewall made no difference. I have uninstalled the software and reinstalled several times. It's never worked once. I found the actual application file in C:\ProgramFiles(x86)\Canon\OIPTonerStatus\CnTnrStsApp.exe. Clicking directly on the file or trying to run as administrator yields the same results...nothing. Clicking on the icon in the lower right corner of the taskbar produces a Toner Status error message that reads "No printer driver that supports Toner Status was detected. Install a printer driver that supports Toner Status, then perform the operation again." Any ideas? Thanks.
10-24-2023 03:51 PM
Hello Gabehobbs,
