02-25-2021 04:22 PM
I received warning msg Cartrige ink is low, asking me to check Consumable and Press/Hold Volumn Key, I did all but printer is not printing.
02-27-2021 09:38 AM
The 634Cdw is a laser printer. It uses toner. Note which toner the printer indicates as low.
Then, power the printer off, open the front cover and slide the toner drawer (carrier) out.
Carefully remove the toner that printer reports as low. Hold horizontally. Go outside, as this can be messy. Carefully shake the toner side to side for 15~30 secs. Now reinsert it. Close carrier, front panel and power on. If there is still toner available, you should be able to print again until its depleted.... time to buy more toner.
If it still states low or depleted, the toner cartridge is either empty or there is another issue.
