02-17-2025 12:41 PM
It used to work fine. Then, I would print double sided and it would print the first page and then make an accordion out of 1/2 of the page and jam the printer. I would turn the printer off, remove the jam and then it would work. Now, it just does the same thing and jams and won't print 2-sided anymore. Please Help. Thank you.
02-25-2025 03:54 PM
I had already run the maintenance tasks and talking with a service rep did not solve the problem. It seams the solution is unfortunately "get a new printer".
02-17-2025 06:20 PM - edited 02-17-2025 06:21 PM
If the unit has any maintenance tasks available, and they haven't been already run, give them a whirl.
Something may be out of alignment. If so, a call to Canon Customer Service might be worthwhile.
02-25-2025 03:54 PM
02-26-2025 07:26 AM
Unfortunately, the cost to repair many smaller copiers often exceeds the price of a new/replacement unit. 😕
02-26-2025 11:24 AM
Yes, that has been true for almost all electronics for quite some time now.
02-26-2025 04:09 PM
What are you printing, and what paper?
Putting a lot of ink on ordinary 20 lb. copier/laser paper can make the sheet soft and flimsy, causing it to jam.
02-26-2025 04:28 PM
Hi normadel,
The printer in question is a monochromatic laser unit, so over inking won't apply in this instance.
