LBP6000 doesn't work after upgrading to OS X 10 yosemite (beta)
smukhi
Any suggestions?  Solutions?
4 REPLIES 4
knipprs
I just upgraded to Yosemite (I assume it is no longer Beta), and my Canon LBP6000 stopped working.  If anyone has a suggestion, I'd like to hear it!
Patrice
Whiz
Hi smukhi and knipprs!
 I will be glad to assist you.  The driver is now available for the commercial release of the OS X 10.10 (Yosemite) driver.  I recommend uninstalling the previous driver before installing the latest driver.  To uninstall the driver, please follow the instructions below:
1. Click the [Printers & Scanners] icon in [System Preferences].
2.Select the printer you use on [Printers], then click [-].
3. Delete the printers that are registered, then close the [Print & Scan] dialog box.
4. Open Finder application of your Mac OS X.
5. Select [Go] → [Go to Folder] from the menu bar.
6. Enter the following folder locations, click [Go], then delete the files and folders.
Delete Example: You can delete files and folders by dragging them to the [Trash] icon in the Dock.
Location
Files and folders to delete
/Library/Printers/Canon/
CUPSCAPT
/Library/LaunchAgents/
jp.co.canon.CUPSCAPT.BG.plist
/Library/Printers/PPDs/
Contents/Resources/
Delete all the following files in the folders.
CNMCxxxAUS.ppd.gz
(xxx is a model name starting with [LBP].)
When the [Authenticate] dialog box is displayed
Enter the administrator's name and password, and then click [OK].
7. Close all open windows.
8. Restart your computer and empty the Trash Bin.
The printer driver is uninstalled.
Next, go to the imageCLASS LBP6000 - Drivers & Software page, and then download the file CAPT Printer Driver Ver.3.67 for Mac OS X 10.5/10.6/10.7/... listed under the [Recommended for You] section.
After installing the printer, please follow the instructions below to add the printer:
2. Click [+].
3. Click [Default], and then select the printer to be used from the printer list.
4. Select [Select Printer Software] from [Print Using].
5. Select the printer to be used from [Printer Software], and then click [OK].
6. Click [Add].
7. Make sure that the printer to be used is displayed, and then close the [Print & Scan] dialog box.
The printer registration is now completed.
I hope this information is helpful to you.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
I just downloaded the new 3.67 Driver but I can't find my printer LBP6000 When I want to add the printer, What should I do?
i am having the same problem when i get to step 8, of the first instrucions i reboot the computer. it starts up and i download the driver and when i try to install i get this error
canon capt printer driver can't be installed on this disk.A later version of canon CAPT printer driver is already installed. and i get the                    harddrive symbol                          and a                   driver symbol
                                Macantosh HD                                                         Mac_CA...0_us_EN
                                360.85 GB available                                                 16 MB available
                                499.25 GB total                                                         30.7 mb total
