Imageclass printer cancels print job at printer
dkittleson
Not sure what does this.  On occassion the printer just doesn't print.  I see the data green light on flashing.  Then 1 beep and that's it.
I can print other PDFs.  I can print word docs.  It just seems every so often there is a PDF it just won't print.  Thinking the file may be too big I've even broken them down into 1 page PDFs and stil lthe same thing.  Screen Shot 2020-03-09 at 8.12.22 PM.png
No error code.  I can't figure this out yet it's frustrating as all get out.
12 REPLIES 12
switham
I have a similar "Print job canceled at printer." problem using "lp" with plain text on a Linux system (Raspberry Pi OS).
But then I went to the printer's own web server.
If someone else wants to see this: find the printer's local IP address.  Mine changes over time; I don't remember how to find it in the printer's menus, but somehow I got mine set up with the Bonjour / Airprint / Zeroconf name "Canon_LBP622C.local".  (actually I'm changing the name here.)
So I can say, e.g. ping Canon_LBP622C.local, and the ping shows the 192.168.2.6 or whatever it is today.
But, I can also just use the ".local" name in my browser (in my case http://Cannon_LBP622C.local )
to bring up the web interface for the printer.
To "log in,"
Check General User Mode, no user name, hit Login button.
"Status Monitor / Cancel" button.
Then on the left under Print, "Job Log".
I had done two things on the Raspberry Pi, and a third test on my Mac, which has been having no problems:
First thing: On the Pi: Linux uses the CUPS printing software.  Try to print by entering the unix command "lp", then type hello (return), then type control D (end of file).  The computer says,
    request id is Canon_LBP622C-5 (0 file(s))
This job just produces a beep on the printer.
The log entry for this on the printer web page is hard to reproduce in this comment but the interesting parts are:
Job #:   158,  Result: Error, Job Type: Printer, File Name: (stdin),
Original Pages: 1, Output Pages: 0, Sheets x Copies: 0 x 0, Error Code: #822.
Second thing: Still on the Pi, start the "Mousepad" editor, enter hello, go to the File menu and Print.
The printer prints "hello" in a typewriter font.
Log entry:
Job #:   159,  Result: OK, Job Type: Printer, File Name: Mousepad job #1,
Original Pages: 1, Output Pages: 1, Sheets x Copies: 1 x 1, and no error code.
Third thing: On a Mac (Macs also use CUPS printing), do the "lp" command typing "Hello."
The computer says,
    request id is Canon_LBP622C_623C_long_string_of_hex_digits_ (0 file(s))
The printer prints "Hello" in a Helvetica-like font.
Log entry:
Job #:   160,  Result: OK, Job Type: Printer, File Name: (stdin),
I have a feeling the Mac is using the "enscript" utility to turn the text into Postscript before sending to the printer, but I don't know how to manually configure that on a Linux system.
A Cannon page about printer error codes:
Countermeasures for Each Error Code - Canon
822: "An file in a USB memory device could not be printed because the format of the file is not supported.
Check the supported file formats and save the file again.
Printer Functions"  -- which links to a page including this:
Memory Media Print Function
Printable File Formats
JPEG (DCF/Exif 2.21 or earlier/JFIF)
TIFF (JPEG/MH/MR/MMR compression)
PDF (Version 1.7)
Although I don't see how this relates to memory sticks, this list doesn't seem to include plain Unix text files.
 --Steve
krishkal
Going back to the original poster's problem, I too have the same issue with imageClass MF644Cdw printer.
Some PDF's and PNGs from my Macbook will not print - the LCD shows that the data is being received, but when that is complete, the printer emits a long beep, and does not print.
I tried the following experiments with a PNG that refused to print just now -
1. Print from Preview app - NO printout
2. Open Pages, create a blank document, and embed the PNG into that document, then try to print from Pages - NO printout.
3. Open the PNG in Preview again, and export it as PDF, then open the PDF in Preview and try to print - NO printout.
4. Open the PNG in Preview again, and export as JPG. Then open JPG in Preview and try to print - SUCCESS!
If you want to reproduce my problem, the particular PNG I used is available on Wikimedia - https://en.wikipedia.org/wiki/Vande_Mataram#/media/File:Vande_Mataram_-_Bankim_Chandra_Chatterjee_(R...
anandvc
I solved this problem by printing via my Android phone, which sends the document to some kind of Google cloud print server, and that makes it work. I'm not sure why.
Friends and Family
