12-22-2021 05:00 PM
I am attempting to print checks from Quicken (3 to a 8.5" x 11" page). My problem using the multi-purpose tray to print an individual check (x = 4"; y = 8.5") or two checks (x = 7.5"; y = 8.5") on partial sheets. I have registered the custom paper sizes and select the correct one when I insert a partial sheet into the multi-purpose tray, putting it properly into position and adjusting the tray size. When I attempt to print, I get a "Paper Settings and Loaded Size Mismatch" error and the checks do not print.
I am running the latest version of Quicken, R36.56 on Windows 10. I have tried the "Edge" and "Centered" partial page settings in Quicken.
Greatly appreciate any help on how to print these custom paper (check) sizes with my MF445. Thank you.
12-22-2021 05:07 PM - edited 12-22-2021 05:12 PM
Its been a long time since I've done this.
What happens if you stick with 8.5 x 11 and only populate the first or second checks when there are less than 3?
Other possible solution here:
How To Set Your Printer To Print Checks in Quicken
12-22-2021 05:17 PM
Thanks for your reply. I can print with no problem on a full-size 8.5" x 11" sheet. The problem occurs when I have only one or two checks to print on partial sheets, which is often the case. BTW, I'm coming from a Lexmark which had no problem doing this - and without asking for a custom paper size.
12-23-2021 02:49 AM - edited 12-23-2021 02:50 AM
I do this with labels all the time. 30 on a sheet, but rarely print 30 at a time. So I load the 8.5 x 11 sheet in the printer and start at the column and label I want to print.
If you only have one or two checks after ripping one off, put that in the drawer, choose 8.5 x 11 and populate the first and/or second check.
Or did you try the Recommendation from Quicken above:
The printer will not expect a custom paper size unless you tell it to expect something besides 8.5 x 11.
12-23-2021 08:00 AM
Thanks for taking the time to reply. With labels, you still have a full 8.5 x 11 sheet. Not the case with the checks. The techniques that you mention don't work.
I'm in disbelief that Canon doesn't support a simple function like this.
02-16-2022 02:25 PM
Did you happen to get a fix for this problem??? Im having exact same with Quickbooks desktop. Looking all over online for a fix. Quickbooks was no help on their support. Thank you.
02-16-2022 02:50 PM
Sadly, I've found no solution other than to use a "Forms Leader," which is available from Intuit. It's a slight inconvenience, but it works.
