Imageclass D550 printer/scanner squeals
EJaasma
I removed a jamed paper (probably incorrectly) and since then the printer squals(or squeaks) for a couple of seconds after a printed page exits.  After the page is printed there is a narrow crease or indentation the full length of the paper about 3/4 inch from the left side and a light smearing of the black printing powder extending the full length of the paper from about 5/8 inch from the left edge to 1 1/4 inches.
1 REPLY 1
Audrey
Enthusiast
Hi EJaasma,
Please check for any paper or debris in the printer:
1. Hold the operation panel.
2. Lift the scanning platform.
3. Hold the grip on the left front side of the toner cover.
4. Open the toner cover.
5. Remove the toner cartridge.
6. Remove any jammed paper or debris by pulling it gently.
7. Push up the green colored part and then pull the paper exit guide to open.
8. Remove any jammed paper or debris by pulling it gently.
9. Lift the paper exit guide, and then firmly close it.
Ensure that each end of the paper exit guide is closed.
10. Remove any jammed paper or debris by pulling it gently.
(1) Gently pull any jammed paper downward from between the fixing unit and roller until the leading edge emerges from the machine.
(2) When the leading edge emerges, hold sides of the jammed paper and carefully pull it out.
11. Remove any jammed paper or debris by pulling it gently.
12. Lift the dust cover.
13. Remove any paper loaded in the paper cassette.
14. Remove any jammed paper or debris by pulling it gently.
15. Reload paper into the paper cassette and lower the dust cover.
16. Open the rear cover.
17. Remove any jammed paper or debris by pulling it gently.
18. Close the rear cover.
19. Insert the toner cartridge.
Fit the protrusions on each side of the toner cartridge into the guides located on each side of the machine, and then slide the toner cartridge into the machine until the toner cartridge meets the back of the machine.
20. Close the toner cover.
21. Lower the scanning platform.
This information is availabe in the manual with pictures. The manual can be downloaded from the Canon D550 website by clicking HERE. Click on MANUALS button.
The Forums aren't intended for immediate assistance. If this is required, we will have to recommend that you call our telephone support group. Please call 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays). A representative will be able to further assist you.
