03-05-2021 10:56 AM
I am using an ImageClass D1520: paper crumples / rips when paper is being pulled from the paper tray.
Issue:
1) Copy printed crooked
2) Right edge of paper crumples/tears - obviously due to being pulled into path crooked
Problem-solving attempts:
1) Opened brand new pack of paper (we go thru new reams daily so paper does not sit unopened for more than a few hours)
2) Have tried a different brand of paper
3) Checked the paper guides on side and back in paper tray
4) Paper is not loaded above back guides in tray
Seems to improve as the paper is used and is less in the tray.
Any ideas that may help? Appreciate it!
04-27-2021 01:39 PM
Hello,
If the paper feeds in crooked and you have already tried adjusting the paper guides, it sounds like there is something in the paper feed path or there is something wrong with the paper feed. In this situation you can use the steps in the link provided HERE to check for locations that paper can jam. You can check those locations for small pieces of paper or obstructions in the paper feed path. Pay close attention to the side of the printer that rips the paper.
If you do not see any obstructions, it does sound like there is a problem with the printer. In that situation, you can check your service options by logging into your Canon account using the link HERE.
06-14-2021 03:45 PM
6/14/21
HAVE SAME EXACT ISSUE AFTER HOURS , I SEEM TO FIND ,IF THE MACHINES HAS BEEN IDLE THIS ISSUE HAPPENS. WHEN I UN 20+ PAGES PROBLES SEEMS TO STOP.
FOR SURE IT IS THE IMPUT AREAS AT OR BEFORE THE REGISTRATION ASSY. (PRINTS CROOKED.)
2 SETS OF PICK UP ROLLARS REMOVED REGISTRATIONASSY , CLEAN SEEMS OK, ALSO STRIPPED PAPER TRAY FOUND OK..
RAN ALCOHOL PAG THRU ENTIRE PAPER PATHS CAM OUT CLEAN.
I'M AT A LOSS .ONE OF A FEW IN 60 YEARS. LET ME KNOW ANY THING YOU FOUND OUT.
KEN
06-14-2021 03:46 PM
