12-16-2019 06:06 PM - edited 12-16-2019 06:39 PM
Every time I want to print from a computer, I have to walk over to the printer and select paper size and then it starts to print. The paper tray is loaded with letter-size paper. The multi-purpose source is set for letter-size and is empty and closed. I have even set "Copy" to letter size. Everything is set for letter size. The printer will not print without going over to it and selecting letter size paper. I must be missing a setting somewhere. I am trying to print from the main paper tray, which it does after I select paper-size. Thanks for any help.
12-16-2019 08:39 PM - edited 12-16-2019 08:40 PM
Hopefully this will help.
<Menu>
<Function Settings>
<Printer>
<Printer Settings>
<Default Paper>
Select the paper size
Select the paper type
Here's your online manual
12-17-2019 05:32 AM
Thank you for your suggestion. I followed them and it did not change a thing. I still have to go to the printer to select paper type after trying to print from the computer. Thanks again.
12-17-2019 08:07 PM
Then it sounds like you may have unintentionally changed the default paper selection or size to something other than or whats loaded in Tray1? Look at the printer preferences (Driver) on the computer.
Here's an example
12-20-2019 12:45 PM
Hi azlife4me.
In addition to Shadowsports' recommendation, I also recommend checking the printer's driver to see whether the Output Method is set to Secure Print.
Secure Print will require you to manually enter a pin and possibly check settings when printing. If it is set to Secure Print (or another Output Method that requires attention), try changing it to "Print."
12-20-2019 12:48 PM
Thank you.
