04-29-2023 04:34 PM
I've been trying to wirelessly setup my Canon ImageCLASS MF632 with my computer on Windows 10, but have run into some issues. My printer is connected to WiFi (same network as my computer), and I have downloaded the drivers.
To add my printer to my computer, I used the printer's IP address, as my computer wasn't discovering it. However, my printer is still listed as "offline," and the "use printer offline" option is turned off.
In addition, my computer's troubleshooter returns these responses:
These are the troubleshooting measures I've taken that haven't worked:
I'm at a loss, and can't call Canon support as the ImageCLASS MF632 is no longer supported by their agents.
Any help would be wonderful! Thanks in advance.
04-29-2023 11:21 PM - edited 04-29-2023 11:30 PM
A few questions.
Windows 10 OS. Do you have a 3rd party AV application installed?
What is the brand and model of the wireless router?
How did you create or assign the static / reserved IP?
Does the router show the printer in its list of attached devices, and using the IP address you assigned?
Can you ping this IP address from a command prompt?
Example mine is 192.168.1.99
C:\Users\itadmin>ping 192.168.1.99
Pinging 192.168.1.99 with 32 bytes of data:
Reply from 192.168.1.99: bytes=32 time=12ms TTL=255
Reply from 192.168.1.99: bytes=32 time=4ms TTL=255
Reply from 192.168.1.99: bytes=32 time=3ms TTL=255
Ping statistics for 192.168.1.99:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 12ms, Average = 5ms
I'll wait for your reply.
