02-03-2024 07:34 PM
This printer is about a year old. We use it wirelessly to print from laptops, desktops, phones, tablets. It was super easy to set up and has been a breeze to use until a few months ago. I leave it powered on and it's in energy saver mode most of the time. Usually I can send something to it while it's "asleep" and the act of sending a print job to it wakes it up. But it stopped responding while asleep, so I started walking over to it and waking it up before printing. Then it stopped automatically connecting to my home wifi, so I would have to go through the process of manually setting up the wireless LAN and then it would print fine for about a week before I'd have to manually connect it again. And now I can't get it to print no matter what I do. Please, please help!
First thing I should point out is that my toner level is at 10% right now. I have a cartridge ordered but I usually keep it on hand until I get to the very end so as not to waste 10-20% of each cartridge I buy. The error messages I'm getting aren't related to the toner level, aside from the notification in the corner.
"Could not connect. Check the PSK settings" is the error message I receive when I attempt to connect the printer to my home network. I believe all this means is that I entered in my password incorrectly. But I have retried it more than enough times to know that the problem is not a password issue, case sensitive or otherwise.
I decided that there must be a problem with the wireless card (or whatever the little gadget inside that connects it to my wifi is called). So I bought a USB-B to USB-C cable to connect it directly to my laptop. Select wired/wireless LAN, chose WIRED. Then I chose direct connection settings; Use direct connection - ON. Now when I try to print something, my printer choices include two options; the original wireless canon and then the exact same one but with my laptop listed in parenthesis next to it. I assume that is the one that is plugged into my laptop. But the little print job window still searches and searches and when I look at my printer settings both "printers" are "offline".
Because being wireless is a key feature of this printer, everything I search for online is about connecting it wirelessly and I don't know if I'm missing a step for wired connection or if my printer is simply worthless within the first year of use. I've only gone through 2 full toner cartridges since I bought it (not including the "small" one that came with it).
Oh! And I did reset it to factory settings yesterday after a few power reboots and leaving it powered off overnight (because maybe my power cycling was too rapid?? I have no idea)
Thank you in advance for your help!
01-22-2025 01:02 PM
Hello,
The wired/wireless options on the printer would be for using an ethernet vs a wifi network connection. The USB port on the printer will always be active. If the USB and network connection are both offline, it looks like the printer is not connected to the network and the USB connection is not working/disconnected. In this situation, I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to check the network settings to see what is going on.
