I need to print double-sided to a 4x6 postcard on a MF8380cdw from Word on Mac OS X
Duckbert
I need to print double-sided to a 4x6 postcard on a MF8380cdw from Word on Mac OS X. The display in Word looks just like I want it to be on the postcard. The page size in Word page setup is postcard. I even tried a custom 4x6 paper size on the printer, but I still get the error light when I try to print.
1 REPLY 1
Patrice
Whiz
Hi Duckbert.
I will be able to assist you.
You may need to adjust  the paper settings directly at the imageCLASS MF8380Cdw to match the 4" x 6" size in Word? Please follow the instructions below to adjust the paper settings:
***Please note that the instructions are for the Multipurpose Tray. Follow Steps 1 and 5 - 9 to set the paper cassette tray.***
1. Press (Select Paper/Settings).
2. Scroll to [Paper Settings], and then press [OK].
3. Scroll to [Multi-purpose Tray], and then press [OK].
4. Scroll to [ON], and then press [OK].
5. Scroll to [Paper Settings], and then press [OK].
6. Scroll to [Multi-purpose Tray], and then press [OK].
7. Scroll to [Set Details], and then press [OK].
8. Scroll to [Custom], and then press [OK].
Specifies the size of <X> direction and <Y> direction of the custom paper:
(A) Select the direction with the Up or Down arrow keys, and then press [OK].
(B) Specify the size with Up or Down arrow keys, and then press [OK].
You can also enter values using the numeric keys.
(C) Select <Apply>, and then press [OK].
9. Scroll to select the [Heavy Paper] setting that matches the weight of the postcard, and then press [OK].
If you still experience an issue, please call us at 1-800-OK-CANON (1-800-652-2666) for further assistance.
