06-01-2023 08:54 PM
I found the following solution for a different printer:
https://support.usa.canon.com/kb/index?page=content&id=ART166426
It does not relevant.
Please help
07-11-2023 03:57 PM
Hello SharonCanon,
To customize the scan settings, you can open the MFscan utility on your computer and then click the option for settings. In the setting window, you can click on the option for custom 1 and then you can adjust the scanner settings. you can use the steps in the link HERE to view how to change the scanner settings.
If you would like help with adjusting the scan settings, you can also contact support over the phone at 1-800-652-2666. Our agents would be happy to help.
