03-16-2021 12:46 AM - edited 03-16-2021 12:48 AM
Hi Guys,
Need help. i brought a new Mac Air with Big Sur 11.2.3 OS last week.
Canon Website has only up to 11.2.1.. i need the driver please.. i couldn't find it anywhere to download.
thanks in advance guys..
-Gary
03-17-2021 11:39 AM
I suggest trying the 11.2.1 driver. It may work, but you won't know unless you try.
It might also be a good idea to contact Canon. Your device will need to be registered, even if not under warranty in order for you to use the chat function. It would be helpful if you let them know you are hoping for continued support under Big Sir.
03-19-2021 11:26 PM
I always start here:
06-01-2021 01:24 PM
Hello GaryOak,
We currently have drivers on our support site for 11.2.3 and you can download them using the link provided below. Usually the drivers made for a version will work on all versions of that OS. The 11.2.3 version will work on 11.2.3 -11.2.9. Once Apple releases a major change to the OS like 11.3.X, I would suggest checking for an updated version of the driver using the same link below.
06-21-2021 07:46 PM
Hector, don't look now, 11.4 is out.
