Reply
Highlighted
New Contributor
Have a MF8580cdw have a cannot print rx data error - help
We have a MF8580cdw printer, and came in this morning to find the red error code blinking - it says cannot print rx data. How do I fix this?
Re: Have a MF8580cdw have a cannot print rx data error - help
Hi EISSOLAR.
I will be able to assist you.
This error appears when the machine attempts to receive a fax when the toner is low.  You will need to enable the "Continue Printing When Toner is Low" function.  Please follow the instructions below to perform this operation.
1.  Press [Menu].
2.  Scroll to [Fax Settings], and then press [OK].
3.  Scroll to [RX Print Settings], and then press [OK].
4.  Scroll to [Con't Printing When Toner is Low], and then press [OK].
5.  Highlight [On], and then press [OK].
Once the function is enabled, you will be able to receive faxes.
I hope this information is helpful to you.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
New Contributor
Connot print RX data errer.Conon MF8580cdw
New Contributor
-Be sure to check your paper settings. While trying to print photos from the multipurpose tray, I accidently set the main paper tray for heavy bond 23-26 and it brought about all sorts of problems, incl no faxes (RX data thing). I set it for plain 19-23 bond and all the problems went away.
powered by Lithium
