01-09-2025 05:25 AM
I looked up a guide on how to set it up on canon's website. Did everything but it's not working. I'm using Gmail account for the printer.
Settings:
SMTP Port number - 587
SMTP server: smtp.gmail.com
Email address: ****@gmail.com
✅ SMTP authentication, ✅ Set/Change password
I have App password set up in Google account for the printer
01-11-2025 11:29 AM - edited 01-11-2025 11:32 AM
Greetings ,
I'm sure @lithoman meant to type "use port 465". You cannot use port 486 with Gmail.
Google only allows SMTP relay on ports 587 or 465, 25 will not work.
Your settings appear to be correct.
smtp.gmail.com
Username is full @gmail.com address
16-Digit app password (note) be careful if you're using, copy and paste as this can introduce spaces)
My printers are configured to use port 587
TLS needs to be enabled
01-11-2025 10:29 AM
#806 is an invalid username/password response from gmail. Since the app passwords are one time use per machine you may need to delete and recreate. If you are trying to reuse a app password for multiple machines, that won't work. You need to create an app password per machine.
01-11-2025 10:33 AM
I'm not trying to reuse an existing one. I created that Google account just for that printer.
01-11-2025 10:44 AM - edited 01-11-2025 10:45 AM
Perfect, I still would delete and recreate. Google gets a bit finicky. Also try port 486 and 25. Yes it sounds odd but have had that work in the past when 587 gives issues like this.
Also, log into the web side for that account. Check the security area and device location. I have seen google lock out the "unknown device" until you accept it. Usually though there is an email in the account inbox stating the security issue.
01-11-2025 10:51 AM
Let me clarify, sorry. Delete and recreate the app password for that device.
Greetings ,
smtp.gmail.com
01-11-2025 11:32 AM
Correct Rick, good catch. I fat-figured that one.
01-17-2025 11:52 AM
Thanks, it's working now. It was either the password (I may had pasted it with the spaces) or that I had TLS disabled.
01-17-2025 12:06 PM
Glad it's working. @lithoman was on this as much as I was so his posts were as helpful as mine. 😀
