02-07-2024 03:34 PM - last edited on 02-07-2024 03:37 PM by Kristoff
I have an ongoing issue with faxes being stuck in que, even after choosing to delete. I am manually having to go in and remove them through services, spool....
How do I fix this issue?
Also, if a fax doesn't go through, does it stay in the que and then retry to send? If so, how often does it try to resend?
Windows 10, everything is up to date.
MB2720 machine
01-29-2025 01:08 PM
Hello,
When sending a fax, the MB2720 will try to auto redial if it fails. You can disable the auto redial from the touch screen on the printer under Fax settings. The jobs can be stuck in queue if the printer is still trying to fax or is redialing.
01-29-2025 01:08 PM
Hello,
