04-14-2024 08:25 PM
I'm trying to disable the auto-update feature on my MF656cdw, as I prefer to manually update on all my devices. I am unable to find any control for this. The update path on the printer's control screen allows me to manually initiate an update, but I cannot find any control for the auto-update. Am I missing this somewhere?
Many thanks in advance for any assistance.
04-15-2024 06:16 AM
04-14-2024 08:47 PM - edited 04-14-2024 08:48 PM
Greetings ,
The printer does not have an auto-update feature like you describe. It's firmware can be updated manually using the control panel or by using the firmware upgrade tool which is downloaded from its support portal. Driver updates could be updated by your OS if allowed, but typically the version you install are the ones the printer will continue to use unless you initiate a change.
04-15-2024 06:16 AM
Many thanks Rick!
