Dirty Print
Cargoman
hello, I have a LBP7200 printer and the print is getting dirty with red ink recently.
May i know how i can clean the cartidge roller to receive the fine print again,
Your help will be much appreciated.
Hello Cargoman,
You should clean the fixing roller (Cleaning 1) and transfer belt (Cleaning 2) to restore the print quality of your Color imageCLASS LBP7200Cdn.  Click HERE to view the steps to perform the cleanings.
If the issue persists after cleaning, before you replace your toner cartridge, I recommend contacting us at 1-800-OK-CANON (1-800-652-2666) for further assistance.  I understand that the forum may be your preferred method of communication; however, speaking with our telephone technical support group will be very beneficial in this case.  There is no charge for this call.
If you're outside of the US, please click http://Canon.us/4xf7 for support options.
3 REPLIES 3
James_C
Moderator
Moderator
Hi Cargoman,
I recommend cleaning the fixing roller.  Click HERE for instructions.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Hello,
It is not imroved after several times in the cleaning on fixing roller,
shoudl i clean the ink cartridge instead.,
Thanks.
Hello Cargoman,
