01-26-2023 03:15 PM
Our LBP151DW printer has developed streaking on each page printed. I followed all the instructions on how to clean the fixing unit (Canon Knowledge Base - Cleaning the Inside of the Printer) but when I click "OK" to start the cleaning, I immediately get a "Could not perform cleaning" error message.
The printer is connected to the computer via USB and the computer is running Windows 10 Pro (version 21H2, OS Build 19044.2486).
Any help would be greatly appreciated.
02-24-2023 06:22 PM
Hello,
If you are getting streaks in the print, it could point to a problem with the toner or hardware. If you have already tried cleaning the fixing assembly and it will not start, you can try reseating the toner cartridge and gently shaking it to make sure the toner is evenly distributed. If you are still unable to clean the fixing assembly and still have the issue, you can try replacing the toner cartridge.
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
02-24-2023 07:50 PM - edited 02-24-2023 08:03 PM
@HomesteadLRS,
An issue with your toners could be the problem. There is also a setting that if enabled keeps the clean fixer assembly operation from completing manually. I think it might be "Auto clean fixer assembly".
03-07-2023 02:51 PM
Hi Hector
Thanks for the reply. The issue does not go away when we change toner cartridges. The toner we are using are 3rd party toners that are available on Amazon.
This printer is quite old and we are in the process of purchasing a new Canon printer to replace this one.
Thanks again.
