08-04-2022 12:30 PM
My computer won't recognize the machine - anyone out there who can help
08-04-2022 12:38 PM
Hi, StevenM!
So that the Community can help you better, we need to know exactly which version of macOS is running on your Mac and whether your computer and your imageCLASS MF269dw talk to each other via Wi-Fi or via a USB cable. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-04-2022 01:11 PM
10.14.6 Mojove because I'm sick and tired of all the tinkering Apple is doing that screws up everything. WiFi
Thanks back at you.
08-30-2022 05:42 PM
Hello StevenM,
If the Mac is unable to connect via USB or over a network, you can try resetting the printing system and then installing the printer drivers.
If you are still unable to detect the printer, you can check the Mac's network settings to see if both devices are on the same network. If you continue to have issues, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to help.
07-02-2024 07:21 PM
I have the same problem/issue. I deleted the previous driver, unplugged my printer for several hours. Also, I was previously connected via wifi. In the process of trying to reconnect, on the printer, I did go through the menu and selected direct connection via USB. No luck, no joy. Any further suggestions? My mac is a little older, and no more software updates are available. BUT....... the printer did work when wifi connected. I just got tired of it dropping, and also having to turrn off then turn back on every time I wanted to print. Thought it might be easier, more convenient to just buy a new USB printer cord........ again, no luck. HELP!
