02-03-2021 08:40 AM
I have a new HP Laptop, Windows10. My Printer is in subject line. Installed drivers from Canon. Control Panel shows: Canon MF8000C Series UFRII LT. Windows 10 "Fax and Scan Pgm" shows scanner: MF8000C series. Clicking on "new scan" there is no communication between the laptop to printer not even error messages. However, I can print. Any suggestions or recommendations are so welcomed. ty.
03-11-2021 02:13 PM
Hello,
If you have installed the drivers for the MF8080Cw, there will be a scanner program called the MF Toolbox in your list of programs. That program will be able to communicate with the scanner and you can use it with the steps provided in the link HERE.
If you do not see the MF Toolbox in your list of programs or are unable to find it by searching for the program. You can try reinstalling the [Windows 64bit] imageCLASS MF8080Cw MFDrivers (UFR II / FAX / ScanGear) and the [Windows 64-bit] Patch for Network Scan, USB Scan (Windows 8/8.1/10 using the link provided HERE.
If you are still unable to scan or you can't locate the MF toolbox scanner program, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to assist.
03-11-2021 03:29 PM
Thank you. I will certainly give this a try.
