01-11-2024 12:09 PM - last edited on 01-11-2024 12:11 PM by Kristoff
Hi. I got my new printer yesterday (MF753) and it is already showing 90% remaining on the color cartridges. I have printed very little color, but I did make about 150 copies that were "color" even though the majority were black and white. does the color toner really get used up that quickly if most of the pages are B&W? what about if i print in color and it's very minimal, it's almost like the printer was using color toner to print black and white, instead of the B&W cartridge. hopefully this make sense to someone.
01-11-2024 12:12 PM
Also, does the toner percentage remaining calculated as individual ink colors or does it just reduce the capacity by a percentage for each page printed regardless of the color used?
01-11-2024 12:19 PM
Here is an example of what I mean.
01-11-2024 12:38 PM
01-11-2024 12:40 PM
Thanks for joining the conversation, Printer123456!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
01-11-2024 12:50 PM
One thing worth noting. Page yield also depends on the percentage of ink coverage. So if page yield is rated at 2500 pages with 3% coverage and your prints are 5%, the number of pages you get (yield) will be lower. Not sure if this applies in your situation or not.
01-11-2024 01:38 PM
Yeah that does make sense i just thought it was odd that the percentages went down equally at the same time.
01-11-2024 07:57 PM
I have the same printer and am getting the same results. I've only printed one color photo and roughly 100 b/w pages. My b/w cartridge is still at 100%. However, the color cartridges all are at 90%. Something wonky's going on.
01-12-2024 12:29 AM
Has anyone else experienced the same? Is it a firmware update? Anyone from Canon that can weigh in?
01-13-2024 10:02 PM
Anyone from canon have an opinion?
