04-28-2020 01:06 AM - edited 04-28-2020 04:54 PM
I have a Color Imageclass LBPb22Cdw with Windows 10 and hooked up wired to my computer. I get this squiggly line going down the paper and the ink just wipes off the paper where that sqiggle is? I have tried to do all the cleaning preferences that I have found and tried to wipe the rollers that I can see in the printer.
Is there a way to fix this? I am needing this to work asap.
Thanks.
04-28-2020 08:20 AM
Hello!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your printer (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
04-28-2020 02:12 PM
I am using Windows 10 and I am hardwired into my computer.
05-11-2020 12:40 PM
Hi melanieosier.
SInce you mention you've already performed the cleanings (and the problem has persisted), then next I recommend going through the special processing options for settings that may be relevant to your printer's environment. I particularly recommend trying either the High Humidty or Low Humidity setting, depending on which applies to the printer's environment. Humidity can cause the toner to not fix correctly to the paper. Some of the other settings may also (or alternatively) apply.
If this answered your question, please click the Accept as Solution button, so others might find the answer.
